SO would all these RCBO's still be able to detect a borrowed neutral from another circuit, or will it not as the neutrals are all common to each other in this setup???
The neutrals are all common, there are no split DP zones on the system...
Think about it, ....the neutral is common to all 3 phases, so the sensing circuit won't see any imbalance. You can have a whole 36 pole 3 phase board with all single or multi phase RCBO's protecting every circuit, ....no tripping!!!
No, but they're not borrowing neutrals. Just imagine in your head that all neutrals in that building are connected to one HUGE neutral bar. (even though you view it as different neutral bars in the building.) so each RCBO neutral fly lead after going through the electronics is connected to the same neutral zone regardless of different boards hence no inbalance no tripping
Sent from my GT-I9100 using Tapatalk
