generally when the water pressure is too low, the shower heater switches off and you get a cold shower. saves a bit on the leccy though.
If the water pressure is low then the pressure switch inside the shower cuts the power to the heating element, this wouldn't trip the MCB.
Just out of interest, how many times did you try to re-set the MCB ?
Beaten to it by Tel, must type quicker lol
I think about 4 or 5 times with the old shower and twice with the new one. The first time I tried the new shower I tried it on the coldest setting then switched to the next setting up then finally the hot setting and in all it lasted about maybe 4 minutes. The next time we tried it (after changing the isolator switch) we set it going on the hot setting straight away and it tripped after about 1 minute or not even that
without the appropriate test gear and the knowledge to use it, afraid you are peeing into the wind on this one.
.. another thing, the old isolator switch has 45amp written on it but the new one has 50amp written on it even though in the shop it had 45amp written on the price ticket sticker (B&Q) does that make a difference at all?
Thanks, my bet with Spartykus is looking a little bit better (pardon the pun)
does the 45/50amp thing make any difference? (my previous post)
not a scrap of difference, the A rating is the rated max. load for the switch. either there is in excess of 60A going through that MCB, or it's knackered.
Do you think that maybe the old shower was knackered after all then and I haven't wasted £120? I would really like for that to be the case :)
Would it have taken a fault to knacker the MCB to start with or do they just go for no reason?
could be either, or even the cable, impossible to guess without being there.... you could have the old shower tested .
if i were on site, i would test cable and shower, then fit new MCB .
Cheers. I will report back with the outcome. With the old shower I had to hacksaw a bit of the plastic connector pipe off to get the nut off to use again, couldn't get it off for the brass olive so the parts may be okay but it couldn't be used as a shower unit again
should have bought a new olive for 20p.
Hi
Personally i wouldn't carry on guessing. Yeah its good to have an input from the experts on this forum (i am not an expert) but until a electrician is not there to test the entire circuit you wont know.
Consider your own safety and the amount you have spent.. i would leave it off and wait for the electrician
as , unlike plumbers, electricians tend to turn up when they say they will.
