E
electricshock
My black test lead has been damaged. cut half way though at the plug end of the lead. Where can i get a replacement plug from?
My original lead is the Unitest telaris 0100 plus. I have the same tester as well.
See this photo for more details of the problem i got.
cpc farnell or ebay.
buy a lead ( or a set ) . cut plug off with a bit of the lead. solder and heat shrink sleeve onto your damaged lead.
excellent idea. one thing I forgot to mention. I have the lead which when plugged in you can plug another lead on top. So you can keep plugging leads in forever. where would i find a lead which has this on it.
cant find it anywhere. im gona try and strip the plug plastic further up so i can get a bit of bare wire to solder together
TESTMETER Forum sponser over there may be able to help a wee PM to him might get results hes over there >>>>>>>>>>>>>>>
stackable plugs. cpcfarnell. or ebay. and as mogga said, try test-meter.
