S
Simon_
Went to visit a customer tonight briefly to have a look at a electric hob that was fitted last year when the new kitchen was fitted. All has worked fine until last week when they switched on the cooker switch/socket for the hob which tripped the RCD. They had the hob checked under warranty as 2 plates didn't work so it was replaced. Tripped electrics again. British Gas electrical came and checked the wiring and did an earth loop impedence test all ok but no IR test!? Said that the problem may be the switch/socket which is about 15 years old or the cable to CU. Any suggestions before I check the IR? Could it be earth leakage? Wondering why it's taken so long for it to trip it.
