S
stumper1961
Keep coming across same problem and every spark has different answer.Sockets and switches should be a minnium of 300mm from edge of sink or cooker what do you do when no wall space ,anyone know the CORRECT answer ?
I don't believe there is a regulation on distance. Just fit for purpose and accessible. 300mm is a guideline, which is usually achievable. I think common sense is the best way where you can't get that distance.
Correct answer is 2 fold
BS 7671-2008 there is no 300mm value for sockets being away from a sink in a kitchen. There use to be in the 16th or could even have been the 15th, time fades the memory, but it as been omitted. There is no 300mm values in either section 553 Accessories or anywhere in chapter 5
In all the Guides associated to buildings and regulations it does recommend that you try and keep that distance, but unless there is some manufacturer or design reason behind the limit, then these are guides and so open to interpretation
common sense should always prevail, except when it conflicts with the ideas of architects, planners, building inspectors, customers, builders, plumbers, kitchen fitters, wood butchers, then common sense goes out the window
Cheers rich, their must be alot of sparks with no common sense putting sockets within 50mm of edge of cookers etc.
Over the top is common from what I've seen too.
I think common sense is very rare on site now lol
Hi,who interpretates its ok to put socket next to cooker? cant be safe
THANKS stumper
I have tried on may occasion to explain to builders who feel they know more about Electrics than a qualified Electrician. In some cases it is not progmatic to maintain the 300mm away from the cooker, with zink I can understand you have to keep it away as much as possible
Pls spead the words
i try to maintain a distance of 300mm between a socket and my cooker, but as she moves around the kitchen, it's not so easy.
Pls spead the words
I know that type......
LOL
THANKS stumper
Next to a cooker .....................me
I would interpret that would be a safe location for the accessory providing it satisfies the regulations, and also IMO more importantly it does not give rise to damage from heat, spills or will be dangerous for anyone utilizing the socket.
Now directly above a cooker I would say no
Most people using cooker would need space either side the socket would more likley be used for portable appliance were the flex could end up on cooker, you must get all your cooking done for you lol
stumper1961,
rich.250,
