B
BigSi
Just got back from one of my customers, after replacing a thermostat in her immersion tank. Now the problem is, that this is a regular occurrence that happens every six months or so. As the thermostats should last a lot longer than this, I’m wondering if something else is at play?
She also has a coal fired Rayburn oven that also heats the water, and stores it in the immersion tank. She mentioned (could of told me earlier), that on a few occasions she has had to come down during the night to open the hot water taps to drain out the boiling water, as there is nothing on the Rayburn to regulate the water temperature.
Now, could this be causing damage to the thermostat? I couldn’t get through to her that the thermostat only controls the heating element in the immersion tank, and not the temperature of the water from the Rayburn.:skep:
