Allow me.
Don't run cables directly onto suspended ceiling.
Keeping things neat may save you time if lots of cables.
Install a run of tray cable or trunking along your main run (ceiling or wall).
If tray, make loops of cable to support your new cables whilst installing then finally tie back in groupings.
If trunking, make up retainers from pieces of 20mm plastic tube cut down the middle. Be inventive. Messy jobs can turn into a nightmare.
Oh, groupings...another subject
The quickest and cheapest way is to use cateenary wire position a few of them and cable tie to it
Hope this helps
AJ
Cateenary sounds good. never tried it but certainly cheaper than trunking, plas conduit, roses etc.
Whichever method you use 'make it tidy' and make it look professional so you can be proud of it.
There is no definative 'right way' to do a job and we should all learning all of the time.
'Make it right'
Uhmm. Thanks AJelec. I like that!
Ive jus finished doing a suspended ceiling myself, jus tie wrapped the cables to the wires which holds the suspended ceiling up and fix 20mm stop end boxes to the concrete ceiling and fit kliks. Alot easier than fitting conduit throughout.
How many of you actually do this.Was in Asda the other day and there were tiles missing.All the cables were resting on the tiles:eek:
Asda prices are very low.
This obviously includes the price they pay for their electrical work!
sounds rough i still have a bit of pride in my job. Besides what do you do if you want to change the layout of the lights?? with my method its unplug move lights then plug in.
I think there's a few people on here shoud stay behind @ school and do line's ......
I MUST TAKE PRIDE IN MY WORK... ;)
Not me i've learnt to switch off when i go shopping and concentrate on the bargains rather than the install:D:D
