S
Spazz
Please post your comments on here - state if you think EICRs should be done every year or 5 years.
Also please state your reason behind your choice - please don't put money!, profit for us, cost to landlords etc!
I will put this forward to Parliament in favor of which one is considered best by the experts in the field (us)
Please sticky this as well please
Yes we still have cowboys doing work without notifying it - but the fault of that lays with the home owner! They should check for NICEIC at least!
NICEIC is widely known and something as easy as a logo on the van or ID is the easy thing- the problem is people dont check!
If you made that statement over ten years ago.it would have a smidgen of truth about it
Nicholas,do you honestly believe that scheme membership gives assurance to anybody that the person is competent or even an electrician in the first place
Surely you are aware that there are as many competent and unregistered electricians,(either not wanting, or employed, and not requiring registration) as there are charlatons posing as electricians,kitted out with pretty Niceic logos and the all important incompetence to boot for this part p fiasco
I was waiting for that Des - Yes I am aware - like I said before the government needs to make a campaign to show home owners how to check if someone is registered
Again like I said before the other problem is that these schemes are in it for the money - nothing else!
Again nothing to do with Part P - its the schemes this time!
The idea of Part P is fine - its how it has been put into place.
I know alot blame the Part P but come on - lets have one person explain why Part P is so bad and what can be done about it to fix it that without having a negative effect on anything else - because I promise you now tif Part P solves the problems that you all say - they will make other problems and the same ones will moan again just because they have to find something to moan about!
and notice its always the same ones - says something!
Come on Im opening this to the floor - post a problem with Part P and a solution for it! - otherwise drop this bloody Part P Moan!
What about the drive bys though how are you going to combat that? As I and others have said, bring in what you're proposing and the incidence of drive by I&T will increase exponentially, thus reducing fees and making it uneconomical for anyone to do it properly. Even a perfectly reputable company could unwittingly employ a lazy git, I've seen it a boatload of times where guys make up test results.
I saw a bloke doing a full test using a £7 multimeter from Maplin - NOT a Multifunction Tester - just a multimeter and he somehow managed to provide figures for Insulation Resistance, Ze, Zs and a full range of RCD tests !!!
What was that certificate worth ???
Have any of you had a Gas Safe registered bloke working in your house & have you ever asked to see his registration card? If so, did any of you look at the back of it to see if he was qualified to work on the appliance he was in your house to work on ??
I was CORGI registered for years & never once was I asked by a customer to show my card !!!
The fact is that your average punter doesn't care how many bits of paper or fancy plastic cards you have hung around your neck on a bit of string. All they want is for their appliance to work !!
I have had the Welsh Housing Minister come back to me in regards to this:
He said he thinks its going to cost the landlords more than they are currently spending now
I need an idea of how much landlords/homeowners are spending on an annual basis when they are in crisis mode only
I am thinking about £300 - £500 depending on what goes wrong (per year)
I also have to state the annual cost of EICRs every year and MEICR every change of tenant
Im thinking:
£450-£500 - first year (New CU and MEICR (IR, Zs and RCD Test)
£250 - £300 - every year (EICR and MEICR
Any other ideas on this would be greatly appreciated
I am also thinking - this should decrease insurance policies (reducing risk of fire, electric shocks, etc)
Spend on a crisis basis could be a roof leak a burst pipe in fact a lot of things that are not electrical. The rent has to cover a lot of things not least servicing the loan on the property. There are a lot of people moaning about the rents being to high now and your £250 - £300 per year is another £5 -£6 a week on the rent
You need to look closer to home for landlord costs as you know at least one and you need to focus on all areas of the property costs not just the electrical
Why is it everything you check is going to need a new CU seems to me the 17th regs where designed to educate a minority that everyone needs a new CU as it's good for business
Insurance companies don't ask for EICR's now and if the electrics in every house in the land is as bad as you suggest they are then I can only see premiums rising having drawn their attention to the increased risk they now find themselves insuring
I do agree why should we pay to check that idiot tenants haven't made the installation a hazard!
But you say that its their fault and only their fault - but think about it this way if a tenant modifies something and a landlord does not have it checked then the next tenant is killed (worse case) who is to blame?
THE LANDLORD because they have a legal responsibility to ensure that the electrical installation is safe at the start and during the whole tenancy!
I agree that this is not right but the problem is that this is the case!
somersetspark - you seem like a decent landlord - and like you say everyone that you checked is fine - again responsible landlords but what about those you don't check?
The problem is that those who are not responsible are the ones who let the whole lot down - same as with sparks and everything else!
So what is needed is to have a tenant idiocy test if you are to big an idiot you don't get to rent
How do you intend to police the dodgy electrics on the neighbourhood cannabis farms
The best thing which could happen is that T&I becomes notifiable!
This way all T&I are sent to the LABC - same as MOTs are sent to VOSA
There needs to be policing on this! and the only way that will happen is if all EICRs are sent to LABC.
MEICRs will then become like Pre MOTs - advisable and a good idea to check that the Electrics will pass the main MOT when it comes around.
Even Gas should be the same - all notifiable
We have to notify that the work is up to scratch when we do it in the first place so why should we not have to make sure that they comply year after year after year.
If they become notifiable then it wont just effect rentals - it will effect owned properties as well!
And once the database is formed are you going to go down the street fining householders who haven't got an up to date house MOT and insurance as an electrical fire could burn down the neighbours house. Tony Blair as PM was bad enough but going to Eric Blair's 1984 totalitarian state would definitely be a giant step to far
Guys just to clarify yes the MEICR does not exist but if you read earlier it was/is meant to be an imrovement of the VEICR (Visual) that does exist and that the Schemies are pushing as an interm check between EICRs as I have said before EICR every 5-6 years with a MEICR on change of tenant instead of the VEICR .
Also note as well as ensuring there is a good Ze ,Zs at the sockets and if applicable ensuring the RCDs are operating because as we all know that test every 3 months sticker is just a get out of jail card you would still be doing a visual.
Now on sayng all of this is it going to happen of course not but I am not comfortable with a VEICR because that will be a drive by and sadly me thinks the Schemies will push for this.Maybe one day they will consult with us instead of handing down a dictate
One last point my reasong for converting the VEICR to a improved MEICR is to add some basic checks to the existing VEICR and to point out that there have been a few incidents where the property has lost its earth due to gas/water pipes being changed to plastic
Well if somebody wants to come into my rented house every 5 years and do some half baked EICR which the results will almost be guaranteed to have been made up due to sheer work load, they can nob off.
A rented house is just like any other it falls to the tenant to report any dangerous condition.
Tenants are not allowed to carry out diy without permission/certs.
^ that's what is supposed to happen, does it? - no not always
Is life perfect? - no
Des you say this - what will removing Part P do?
The only thing it ill do is give free rain to anyone to do their own electrics without having a requirement to having them checked after!
This is a licence to kill!
Look at the stats and you will see how many lives where saved by Part P coming in!
These customers are opening the door to these cowboys to do bog jobs then they moan because they had been told to spend more money fixing the problems!
The other big problem is some electricians are signing off Joe Blogs work! These are the worst! And there are some on here doing it - they already identified themselves on other posts!
By the same argument what has bringing in Part P achieved any stats for Part P improving safety must be looked at along with the introduction of the 17th edition so which has had the greater effect in improving safety
How can you or any other person suggest that the number of lives saved can be attributed wholly to the introduction of Part P is beyond me, how many people reported an RCD tripping incident that may have killed them i.e. their live was saved and was the RCD fitted because of Part P or the 17th edition or even the 16th edition regs. I'm sorry but you are peddling meaningless stats that are in the public domain to massage public servants egos and bamboozle people like yourself
You quote "NICEIC at least" so can I assume you and your campaign are pushing for a single registration body as well with the NICEIC as your preferred registration body
You still have not provided any irrefutable evidence that Part P has achieved anything apart from the baseless stats that you keep quoting in this and other threads. Until we have fully intelligent properties that report why the RCD has tripped or why any other incident occurred in the home then it would be hard to quantify and report accurately whether lives have been saved. Just because the figures show less deaths than the year before is no basis as to whether a particular initiative or law is working or not
You don't need to look very far for the major failing of Part P which is a quick course and then part with some money and become a legitimate registered member of a competent persons scheme may be the registration should detail what competance / experience level these people are at
UNG let me sum it up for you it is just a big bl00dy mess the last we need is one main Schemie it scares me as it is with the power they weald plus instead of improving our industry they have single handedly undermined it and as for Part P thank god it is not up here and why because they allowed every body and their dog to seek and get registration to such an extent that all they care about is sales and as for removing a membership because of bad workmanship give me a break lets get this abundantly clear it will take a death before they remove someones subscription and also we are all talking like we hope that they will get out of their white castles well my understanding is that they are lurking on this site but they aint going to admit that any day now.
As I see it their job is to guide / advise established businesses and to train and bring on newbies to the business but instead they stand with a big stick telling people to get in line and make sure you are paying your fees they are more interested in breaking up the trade to that many C&G qualifications that buy the way they are only to keen to sell to you to keep them in their gold plated saleries and pensions remember the debacle of the Part P review or in other words yes we know its a mess but we will not admit it so we will call it a review then there is the yes times are hard so lets change the 17th, I&T PAT testing and do some reviews so that these hard pressed clowns will have to buy new COPs,BGB,OSG new certification certificates
and when we are finished with them they will be begging to sign up to the new C&G courses that we will sell them plus we will show that we care by freezing the fees for a couple of years because they will not notice that we are milking them dry so in other words add all this up and we are screwed. So after all that does anybody still want to wear their Schemie badge with pride. I hope they are reading this because I want to see all of this nonsense cut back as a lawer said in the Levison enquiry "would you like to see new laws against phone hacking" and the witness replied no because there is already laws to protect the individual from that we dont need an extra layer of laws. So Schemies think on dont kill the golden goose
We didn't need it, it just makes more jobs for pen-pushers, it means employed, fully qualified sparks like myself who do not pay into the girt rip-off cannot even undertake work in their own home, while fred in the shed who did a 5 week course and is happy to part with £600 can.
It is purely jobs for the boys and the single worst thing that has ever happened to this industry, letting in essentially unskilled workers and watering down our skills and wages.
It is the end of proper sparks for domestic works im afraid, thats why everyone moans about it.
And then we get people coming along saying we need more red tape in the form of mandatory EICR's, no doubt they would then bring a 'domestic electrical tester' qualification which needed a 3 week course (and the mandatory £600 bribe/scheme membership)
See where i'm going?
Please drop this EICR/RCD stuff
MEICRs only need IR on all circuits (not individuality)
Why would testing the installation or distribution board as a whole not be allowed for the full inspection and test, bearing in mind the effect of resistances in parallel and that the IET specifically recommends that the installation or distribution board should ideally be tested as a whole?
If testing individual circuits then you would need to consider the parallel resistances, i.e. 1/Rt = 1/R1 + 1/R2 + 1/R3 ...
Where to start?
It's a restrictive practice.
It criminalises anyone who conducts many aspects of electrical work who through ignorance or financial restraints does not either notify the LABC or engage a registered tradesman.
Whereas a householder can conduct gas work, it would be illegal for them to conduct some electrical work without paying an exhorbitant fee to their LABC.
It has not achieved it's stated aim of improving safety, nor has it improved standards of electrical installaion work.
If anything it has caused both to worsen.
It's an unnecessary layer of red tape.
To my mind the only people who have benefitted are the LABCs, the scheme providers, the training centers and MFT manufacturer's.
Neither the consumers or electricians have benefited, as they now have increased costs.
Lets face it Testing and monitoring HAS to be done.
I would prefer a recognised,mandatory,NO GREY AREA direction on all domestic properties rented or not. I have worked on decent homes projects for councils and private landlords (some good, some bad). With that in mind i would say an EICR every 5 yrs what ever, regardless of single occupancy or HMO. A visual check version of EICR should be mandatory for all HMO's. This would enable proof of landlords duty of care as well as tenants safety. However, the un registered or slum landlord, tenants with out rental/lease agreements or lets be frank tenants with limited rights for whatever reason is the area that needs to be addressed the most.
Just had an email from the Welsh Minister of Housing
They are going to review the law in regards to EICRs (and possibly RCDs) but not until we are out of the rescission.
This makes no sense at all! Landlords are in the trade that always have a demand for their services
This is the classic rich are getting richer and the poor are getting poorer
I have to disagree with you.
Implementing ill thought out mandatory testing and improvments on to the rental sector will add costs for landlords who WILL pass on the costs to the tenents.
Delaying and thinking this through more is a good thing IMHO.
I think that comment was not the best!
What I am trying to say is that yes putting mandatory I&T will add to the rent.
What I can see them doing is 5/10 years mandatory and advise every change.
This will keep the costs down for the landlord (£160 on average per test - over 5 years = £32, per month = £2.67
This is such a small amount
Yes if they change tenants every year this would cost alot - even more on 6 month changes
Look at it this way people want regulation but dont want to pay and landlords want minimum regulation and dont want to pay. Now in case you have not noticed we are in the middle of a dire economic downturn so the politicians are being pragmatic by not wantingto burden business with what they see as extra cost that will be pased on to the tenant. Plus someone will say well there has been rental properties for hundreds of years and we have enough regulations fo the time being so whats the problem well lets look at the politician we have had parliment for about 500 years so why can we not get things sorted well thats easy as they were building the Scottish Parliment they said it would cost £45 million it actually cost £450 plus my old mum said at the time nothing will happen its just a talking shop because thats what politicians do they talk it to death to show they are doing something because they cannot be seen to do nothing a bit like this issue because as I have said before if we had 20 deaths a week through bad electrics in rental properties then yes the laws/regulations would be changed but that is not the case hence why we will be kicking this can down the road for a few more years yet and ill be muddling through.
Also as I have highlighted before we as electrician have put up with a lot of changes in the last year at our cost BGB On Site Guide,EICR,ISI&TEE(PAT) change in certification, change in C&G because we do not have representation to say hold on these guys are not cash cows stop hitting them in this current climate with all these extra costs. It the same for landlords except they do have representation and are not afraid to use it so I think you will find that instead of new regulations there will be some advisory comments added to the existing regulations
it is understandable to think that mandatory testing of rental properties will increase potential rents and the policy of implementation does need to be thought out. But it must not have any grey areas so as to avoid any rental/lease property from avoiding compulsory T&I, which will no doubt need to be thought through as Murdoch quite rightly points out.
As with anything that comes with new policies or regulations the question of cost/benefit and to whom will be explored and deliberated and probably assumed that its just another money making scheme. However, my point in making it mandatory is not to penalise the responsible but to regulate the so called slum landlords in to ensuring a safe and satisfactory installation.
If and only if it became mandatory the average cost for a EICR would not be £160.00
It woul be like PAT testing, a sticker operation and nothing else.
If part P was doing such a wonderful job then annual EICR's would not be needed. Cant have it both ways.
My personal opinion is that we have enough red tape in the world and there are far more important things to campaign for than this.
You are now trying to make mandatory EICR's a financial penalty for the landlord by the sound of your comment
I think the simple point is landlord is hit by increased expenditure = increase in rent = already financially stretched tenant pays more
Got to agree with this we already have to many laws made in haste and ill thought out
You forgot to add in the hidden costs that could substantially increase your figure not just as simple as the cost of an EICR if you have an agent involved who wants their percentage and the landlord will still want to see a return at the same level on the invested capital
I work for a large housing association and we currently have 70,000 + properties all over UK, we are currently attempting to install testing software to help monitor EICR frequency.
We discussed this with our friends at NIC last week at Castle Greyskull and the general view was EICR every 5 years with a visual condition report if change of tenancy inbetween.
This sounds reasonable and i think as a principal duty holder you would have a strong case for having met your responsibilities
As an electrician you still have the ability as a competant person to shorten that frequency on individual properties if deemed necessary.
The annual gas cp12 seem to get priority but electric doesnt make as big a flash and bang !
Either or both! Many years ago Blair's government gave councils the option of requiring landlords to have a licence to rent a property. I believe this has been enacted in Salford, but not the other areas of Greater Manchester, and I was carrying out PIR's last year on behalf of a letting agent and I believe the council were requiring annual as part of the licence.
The recommended requirement is 10 years or change of tennancy, and it is the change of tennancy that is the killer as this could be 3 month intervals. Another specialist housing organisation I do work for do short term lets which could be for 3 months and is rarely more than a year and they have PIR's at every change of tennancy. Remember there is no guarantee what the previous tennant has done and the owner has a legal obligation to ensure that the following tennant is safe.
I went to one house last year where the live tail feeding the CU had actually been rammed in the base of the main cut out, taking the main fuse out of circuit and leaving about 2 inches of bare copper. THE CUPBOARD WAS ACTUALLY THE KIDS TOY CUPBOARD! The tenant had been there 2 years, and I quickley left and phoned and e-mailed the letting agent from the van. Another house had propogators in the roof with 100's of watts of heat lamps, no plants but the kit was there!
I would suggest that for their own peace of mind protecting their assets full checks should be annual and change of tennancy.
And no, I don't really want the work, crawling round tv's in pooh to get to sockets is not my idea of fun so my price for inhabited is double that of empty!
I agree with Dave 85, what a load of nonsense.
What next, wardens patrolling the streets to take people across the road?
All this talk about safety is purely out of self-interests, and simply another trick to drum up extra work for the trade the same as Part P. did.
So don’t come the safety lark again, we all know what the real reason is behind this compulsory testing proposal.
I invite you to show this post to Parliament.
How on earth can anyone who has not inspected an installation determine when it will need the next one? You would think that an electrician would be best suited to making that judgement.
Some examples then.
If I do a full rewire with new everything I tell the customer that I will be back in 12 months time to have a check round. I don't carry out an EICR as such, and don't produce any paperwork for them unless I find a problem. I have a few fronts off and check terminals are all tight, same for the board. A quick run through the basics with the MFT and that's it. So a new installation is checked after one year, then I recommend the next is due in ten years.
A 20 year old installation which has been worked on for a new circuit or addition to existing I make a judgement on it's condition and put it down for either five years or ten depending on what I see whilst working on it.
A 30 year old instalation with a keen DIYer in residence I'd take it down to two years.
Rented accommodation I recommend change of occupancy, be it 3 months or 3 years.
My name on the cert, my reputation at stake, my knowledge providing the insight. My call IMHO.
As someone who is planning to enter the trade I am Intirgued by the responses to this thread and apologies for the length of this post.
From my current perspective as an outsider I have to say that I believe Part P to be a waste of time in the domestic owner / occupier market - my view here is that most people with common sense will either sufficiently research something before carrying out the proposed work or get someone in who can do it as they realise they are more than likely to be the one suffering if it is unsafe. Those lacking that common sense will almost certainly not be persuaded from doing things just because part p exists, to me this is a classic case of the many being impacted by the few.
The government should have made an electrical safety check part of the home buyers pack when selling a house instead of counting radiator valves, that way any corrective actions would be picked up before a new owner takes on a property and could make an informed decision.
As others have pointed more people are killed falling off ladders or down stairs each year in their own homes than are currently shown to have been killed by shoddy electrics (note I say shoddy electrics, to me genuine accidents like severing cables etc are just that, accidents and should not be included in the debate) - as tragic as any of these deaths are, the response needs to be proportionate, or are we destined to need a certificate in order to elevate ourselves more than 18 inches off of the ground?
Where I feel part p does have value is in the rental / HMO / public spaces sector where an unsuspecting member of the public may be the unfortunate victim of shoddy work caused by a landlord cutting corners, which is where all of this started in the first place.
Most of the letting agents I have spoken with in the last couple of years including my local council now insist on an electrical safety report each year for a property to be on their books. To me an inspection at change of rental should be the norm, for those concerned about short term tenancies my experience is that short term tenancies have substantial mark up in them to cover high occupancy turn over costs.
What is needed is proper enforcement in this area with proper penalties if landlords don't comply.
We need to make a return to common sense and do away with red tape for red tapes sake, I used to work for one of the world largest pc makers, every time I got a new laptop I had to wait to use it until someone had come along and checked the cable and affix his little sticker even though it was brand new and still sealed in it's bag from our own factory, all apparently in the name of PAT testing.
My current employer is recommending employees have an annual electrical check on their houses as we work from home and are plugging in the same dell power supply as thousands of people all over the world - just so they can be squeaky clean on health and safety.
It seems common sense has well and truelly left the building.......Hopefully it will return sooner rather than later even if that might be to the detriment of my future career earning potential.
Paul
Paul
Before any pipedreams about mandatory eicrs are considered,it would be prudent to try and get the percentage of these eicrs actually carried out by qualified and competent sparks, at least to a level where sparks can start to think its actually work thats within their remit
At the moment,most eicrs and most companies who carry them out are a shame on our industry
Weed out this cancer with bog roll testing regimes firstly
It's a crazy system when the genuine spark prepared to do a genuine test and inspection is all but alienated from this arena
its been my expierience that most landlords ive come across seem only interested in the money and only do remedial works if pushed the companies that rent them for landlords are just as bad they send someone round for a look which tests nothing again only interested in the money i recently went to test a property after a tennant complained about the safety she had been in six months i found it to be dangerous
when in the letting agents a snooty woman letting agent says to me theres no law to say it has to be tested which seemed to offend my whole trade and my fellow members so i asked how she new it was ok we just had a walk round to which i replied would you be telling her parents she may end up dead because your chsing the money instead of looking after the client and if im right the landlord must provide the instalation in correct working order which can only be tested to be sure she just shrugged it off i do tests for some landlords and offered a yearly check up service at a reduced rate which a few have taken up so maybe if landlords used the same tester he keeps results and can keep some of the costs down and keep in place the 5 yearly just a thought cheers
i take it your current employer is going to pay for all his staff to have their homes checked when they take the company lappy home then?
No, we get a home working allowance which until recently was about a tenner after tax ( now about 50 quid) a month to cover heat, light, testing etc.
Company has no office so either work from home or out on road.
Paul
Hi des,
Agreed, at the end of day the only way for any change in the rules to be effective is for those eicr's to have some meaning, if they are given away in kinder eggs or not carried out by someone competent then the whole thing falls over.
Paul
I have an HND in electrical engineering, a degree in electrical and electronic engineering, 17 years experience in electrical and electronic engineering.
Over time I have also done a couple of major house renovations including extensive rewires to install clipsal cbus and cytech home automation systems (including getting the relevant training from the suppliers), which have all passed inspection by labc or qualified sparks
So if the above means I am an office boy then guilty as charged.....
Paul
With qualifications coming out of your ear holes Paul
What would be the attraction of entering a trade. that almost exclusively. has been attacked and compromised in all aspects
To such a point that many who have been in this trade,perhaps for nigh on fifty years, actually despair at what has happened to a trade that was once respected and seen as the pinnacle
It has now deteriorated to such an extent that it seen as a add on to everybody else's skills
Where indeed is the attraction
Hang on guys, he's never actually said he's coming into the trade. Yes it's implied by what he said and the fact that he's on the forum but all he mentioned was if his plans come to fruition he won't be doing the job he's doing now.
My question was not meant to be critical of paul,it was critical of his plans (given his higher qualifications status, that he already possess)into a trade beset with decline and low moral
I wish him well,but feel he will be swimming against an unstoppable tide with dreams of regulation of landlords for eicrs
Mandatory EICRs in Rental Properties - 1 year or 5 years
Spazz,
imago,
