Interesting thread.
I've experienced plenty of electric shocks, most of the them, by touching a live wire, whilst standing on a carpet on a wooden floor, with trainers on. Always baffled me a bit.
Like exarmy said, I cant imagine anyone here would fancy standing on a rubber mat then touching a live buzzbar with a wet finger.
Remember on a TT system we use 'the general mass of earth' (ie soil) as a return path. Soil isn't the best conductor hence why we use copper in cables and not soil, but it isn't the best insulator either, and when you add together the total mass (ie parallel paths) then you get a reasonable conductor.
Same with a house - you wouldn't use wooden cables because wood isn't renowned as a good conductor, but the whole floor, walls, plumbing etc of the house added together gives a significant return path.
If houses had earthed copper floors and you were standing on the floor with wet feet when you came into contact with a live part you may not get such a bad shock either because the protective device would operate before you noticed it, depending on the route the electricity takes through your body.
even when you have rubber shoes/slippers on and a live conductor touches your jumper , you still get a fizzel,
Wouldn't fancy trying that one out on a 45 amp 3036
In the days of bus bar distribution for electrical supplies, it was common practice to have to drill the solid bars when all the provided holes had been filled. 9 times out of 10 these bars were drilled while still live, due to factory production etc!! I bet the HSE would have a pink fit and probably die in it, just thinking about it these days ...lol!!
Yes there was a procedure to be followed (of sorts), use of un-earthed drills, shortened drill bits, rubber mat(s), plastic swarf, collector, small rubber sheets wrapped around bars above and/or below, rubber gloves and full face/eye protection, ...and a guy with a big plank of wood standing by!! ...lol!! Still an apprentice the first time i had to do this and a second apprentice then made the connections...
I have no idea how anyone standing on bare wood, rubber mat, with rubber soled shoes can possibly get a belt from touching a 230/240 volt conductor, ...so where is the return path??
It was much more fun If you didn't use swarf collectors.
I was that apprentice holding the plank of wood, when all of a sudden it was like bonfire night because of a wayward bit of swarf.
Those were the days.
EDIT:
Oh and I think the Sparks was more afraid I was going to crack him over the head than he was of a shorting piece of swarf!
Touching live will not always shock you , the danger arises while in the live condition you break the " 1 hand at a time advice ", and touch something earthed with the other hand - UP a ladder !
in all seriousness, i'd like to see someone sheet off the area, place down a rubber mat and then proceed to remove the db cover and grab hold of the busbar
I worked with a guy who I did see doing up a live henley block with an alum key, was only on floorboards but his hands where like leather so no suprize.
I use supposedly insulated steps they are all fibre glass with rubber feet and Ali treads, apparantly these are what electricians should use, not least I guess because Aluminimum is an excellent conductor, and you wouldn't want to swinging them around where potentially Live conductors might be.
Also can someone answer this question please.
We all know how an RCD works, and the human body can be treated as a large resistor, much like TF in a bulb, soooo..if I held the N and the L and was isolated form E would an RCD trip ? or would it just see me as an appliance ?
J
J
Yep it should just see you as a not very clever appliance with a bit of a death wish ;)
LMAO..
I was just wondering if you were using a Class 2 Lawnmower with thick wellies on and you run the N and L through your fingers would it trip ?
J
LMAO..
J
depends on the breaker and how much current you pull. but probably not. assuming you are fully insulated from earth that is!
J
You'd be dead in the blink of an eye. Live in left hand , neutral in right hand , circuit would be completed round about where your heart is lol. ;-)
Yeah and he would die unhappy as he wouldn't be able to check if the rcd had held :)
So if a fault occurs on a Class 2 hand held appliance say from a frayed lead and the user is isolated from E an RCD is about as much use as chocolate condom ?
J
