L
lepoidm
Hi all,
After some sugestions and help please.
The client want a down light in their shower cubical where there is no lighting and 3 walls are tiled, not a problem I hear you all cry.
Here is the problem,
The height of the ceiling is 2200mm therefore making it zone 1. And the roof construction is a flat roof. The clearance between plasterboard and roof is a little over 125mm. I haven't been able to find a recessed down light that can fit in this space... Nor will I...
So does any one know of any lights that can be surfaced mounted with the required IP rating of IPx5? Ideally spots a bit like the surface mounted ones under cupboards in kitchens.
Have thought about a wall light, but simular issue. 2 walls are stud and 1is external wall.
Thanks for you help
Thanks for you help
