Discuss Bathroom lighting problem in the Electrical Forum area at ElectriciansForums.net
L
lepoidm
Hi all,
After some sugestions and help please.
The client want a down light in their shower cubical where there is no lighting and 3 walls are tiled, not a problem I hear you all cry.
Here is the problem,
The height of the ceiling is 2200mm therefore making it zone 1. And the roof construction is a flat roof. The clearance between plasterboard and roof is a little over 125mm. I haven't been able to find a recessed down light that can fit in this space... Nor will I...
So does any one know of any lights that can be surfaced mounted with the required IP rating of IPx5? Ideally spots a bit like the surface mounted ones under cupboards in kitchens.
Have thought about a wall light, but simular issue. 2 walls are stud and 1is external wall.
Thanks for you help
Thanks Ruston, the problem is that will only have 25 mm clearance from the back of the fitting to the roof. Most manufactures fittings just won't meet the required clearance
Yeah they will fit but normally they specify 50 mm or so clearance from the top of the fitting, this would fit it the void but only have 19mm clearance for the timber of the flat roof. Cracking light though.... Liking them
Looking at the manual for the JCC you can lat loft insulation over them so can't see an air gap of 19mm being an issue.
If they're solely LED then there should be no problems with thermal stuff etc. I like them JCC lights.
Interesting..... Shame about the price..... Ok for shower, shame they aren't bit cheaper....I'd use them as standard......look brilliant.
Its for one fitting isn't it.
Surely for the one, when nothing else will do, its a no brainer, surely
Yup! Defo no brainier for one unit..... But not for house that want 15 to 20. People just won't understand the difference between thoses and the cheap £3 crap from Screwfix etc
Thought about led strip lighting ?
Possibly round the edge of ceiling would give a wall wash. Quite a few are ip rated and encapsulated so almost submersible. I used some in a hairdressers round the sink areas and worked a treat. The ip ones are not cheap though but it would tick the boxes without too much agro fitting.
You know what, I have never used them yet. No one asked for them yet. Where do you get yours from in the past please?
Reply to Bathroom lighting problem in the Electrical Forum area at ElectriciansForums.net
