H
hutch6447
I have just tested a function room everything fine all the lights trip at the points ceiling rose/plug & Play on an rcd test, but when testing at the light itself all the lights that were on normal grid switches tripped fine, the 2 that were on dimmer switches didn't trip on rcd test but as I said tripped at the plug & Play.
Do dimmer switches mess with the rcd test and if you bypass the dimmer and it performs OK on rcd test would the rcd trip when dimmer re installed?
