Damo6
I've got three dimmable LED downlights put into my bathroom ceiling operated off a ceiling PIR. As the LEDs are dimmable I asked for a dimmer switch to be added to the circuit.
However I cannot dim the lights.
Taking the PIR out of the equation and wiring the lights directly to the dimmer switch the lights dim as you'd expect.
Taking the Dimmer switch out of the equation and wiring directly to the PIR the lights come on when the PIR is activated.
But with both connected the dimmer doesn't dim, just stays on. When the PIR is activated the lights come on but I cannot dim them.
Any ideas why this is not working as expected?
Damo
At a guess...presumably the dimmer and PIR are in parallel, so when the PIR activates it is effectively bypassing the dimmer.
Can you operate the dimmer without triggering the PIR to see what happens? Cover it up, amybe.
You'd wire in series wouldn't you? Preset dimmer to light level then let pir come on, power the dimmer and lights would come on to where you set them?
- - - Updated - - -
Bet there's not enough load on dimmer, most on,y go down to about 20 w
wholesalers sell a dimmer where you have tune in for small loads, i.e 4 4.5w leds....
but as above can you cover the pir and see if dimmer works
- - - Updated - - -
I'm begining to think this may be the issue. My electrician has more-or-less finished apart from this dimmer:PIR:LED issue. I'll mention your suggestions on the dimmer to him.
Mamy thanks for everyone's input.
So customers come on here to get advice from us to then tell their sparky how to fix it. No wonder you guys get pixxed off and are sometimes a bit prickly
"would this make a difference"
No. As in pir 1st or dimmer. Pir is just allowing circuit to be made, dimmer is dimming. Order irrelevant
Damo6,
SPARTYKUS,
