mmmm college questions are annying glad ive done the college stuff years ago, ive had question where they have missed some of te question out lol
John, once you finish collage is when you start to learn to use the building blocks you are given.
Hi every one sorry for the late reply been at work, I am sorry for not making sence this is actually practical work in the work shop but i have to do the wiring/circuit diagram as home work.
this is what i am starting with it is already put up.
and i have to make a materials list and circuit/wiring diagram for what i have to do
this is a rough drawing of what the finished product should be
i have to wire from the 100 amp isolator below the 3 phase board and my tutor said just assume the board is supplyed by a 3 phase balanced motor so i will not need a neutral from the isolator to the board.
i do not have to wire a motor or even draw a motor i just have to assume a 3 phase balanced motor is connectec into the main 100 amp isolator.
and as i said the only thing i am not sure about is when i wire from the 3 phase board to the single phase board will i have to put a neutral wire in as there is no neutral to the main 3 phase board
Ah... the mist clears!
I'm assuming your supply is on the left.
You need to run a 4 core cable from there (4th core being the Neutral!)
no the supply is not on the left the supply is under the 3 phase board, the isolator on the left is just a swa cable from the 3 phase board to a isolator, i have been told by my tutor that i should not put in a neutral for the 3 phase supply as i should assume it is a 3 phase balanced motor so seen as i am not putting a neutral from the motor to the 3 phase board do i still put a neutral in the single phase board?
OK, wherever the supply is, you need to bring the N from there to the 3P board.
You're right, you don't need the N for the motor cct.
Baker1988,
Baker1988,
