S
soulman
Hi, what size core drill, do you generally use for cutting 100mm core holes 107mm or 117mm.
Cheers
Cheers
you`v to watch it though with 117 cores....you need to leave enough meat in the brick so you can plug n screw the vent to the outside wall....if the hole`s to big...you risk breaking into it when drilling 5.5 for red plugs...
when i was doing bathrooms upgrades for 8 months as all ihad to do was connect and wire a shire and a run on fan i had to drill my own hole for it wasnt long out my time so still pretty nervous working for agency for the council for the first 2 weeks i had a nightmare coreing 4" gun was jamming and nearly breaking wrist and jaw i was for jacking it in then the other spark from 1 of the hole on hammer setting felt like a total tube but then easy days never found the dust that bad the worst thing i would sometime have slight step between the 2 walls inner cavity the outer because i bacuse i would take the pilot drill and just start the second by resting the corer on the first hole
can you not try and write in better English? trying to read that gave me a headache, and i still don't understand it.
