It depends on the fan fitting kit and the wall structure. In a cavity wall with a large 75-100mm cavity you may have trouble lining up and fitting fan and grill flat to the wall on a 107 mm hole and a thick inner sleeve. Usually 117 mm and a good can of foam will allow flush fitting of both fan and vent. Some kits specify 117 mm holes for extractors and some even specify 150 mm +. if you do decide to drill yourself with core drill be prepared for lots of dust!! I usually use an extraction unit and an apprentice to shadow Vacuum whilst drilling, otherwise it gets everywhere and is very fine making it difficult to clean up. Also one of my electrician using a quality hired and serviced clutch drill and core recently broke his thumb when the core snagged and he didn't have a good grip on it (HSE INVESTIGATING!!!)
I tried THIS, still cant understand him.
