Hi all,
I'm not an electrician but one of your customers doing some research so please go easy on me
I have a traditional (not a combi) boiler, with a hot water tank in my airing cupboard, and a cold water tank in the attic.
I have a power shower which makes a hell of a noise so I'm guessing has a pump inside the unit, but I want to move it to another part of the room cheaply.
Could I have your ideas on what options I have please? I am not bothered about having super pressure like I have now. Would a simple electric shower like this be possible with my boiler system?
I have had some quotes for a bathroom refit in the last few days but to be honest I didn't understand the technologies they were talking about and felt uncomfortable to ask. E.g. one recommended a separate 10mm cable run from my consumer unit for something (can't remember what exactly) and one recommended a pump in the airing cupboard for something.
Hope I am making some sense. I posted this in the plumbers forums but didn't get much of a response, then figured out this is actually a sparky question rather than a plumber thing.
if the shower has it's pump in the actual shower unit, you could get the shower replaced with a power shower with it's pump remote from the shower. that would require a sparks and a plumber. alternatively, you could get an instantaneous shower fitted by a sparks, this would require a new circuit from CU in a 6mm or 10mm cable, depending on the power of the shower and the installation method of the cable.
thanks for the reply. The CU is miles away from the shower, so do you reckon your first scenario is less work ? It sounds like I could re-use the electric feed to the current shower to feed a new pump and shower, is that right?
Hi all,I'm not an electrician but one of your customers doing some research so please go easy on me
I have a traditional (not a combi) boiler, with a hot water tank in my airing cupboard, and a cold water tank in the attic.I have a power shower which makes a hell of a noise so I'm guessing has a pump inside the unit, but I want to move it to another part of the room cheaply.Electrics in a bathroom will need a qualified Electrician as a minimum, not worth taking a chance on this! Could I have your ideas on what options I have please? I am not bothered about having super pressure like I have now. Would a simple electric shower like this be possible with my boiler system?Yes, an electric shower is suitable, but depending on the heat output may require a bigger cross sectional area cable (6 or 10mm)I have had some quotes for a bathroom refit in the last few days but to be honest I didn't understand the technologies they were talking about and felt uncomfortable to ask. E.g. one recommended a separate 10mm cable run from my consumer unit for something (can't remember what exactly) and one recommended a pump in the airing cupboard for something.If you choose a powerfull electric shower then your existing cable may not be man enough for the job as it has to supply the heater in the shower as well, not just drive the pump, which is probably why you were quoted for a new 10mm cable.The other suggestion would move the noise and the electrics out of the bathroom into the airing cupboard but would probably involve more plumbing cost and at least a new fused spur for the pump.Hope I am making some sense. I posted this in the plumbers forums but didn't get much of a response, then figured out this is actually a sparky question rather than a plumber thing.
Plumbers !
Sorry my answer has got mixed in with your question in the last post. I'll try again.Hi all,I'm not an electrician but one of your customers doing some research so please go easy on me I have a traditional (not a combi) boiler, with a hot water tank in my airing cupboard, and a cold water tank in the attic.I have a power shower which makes a hell of a noise so I'm guessing has a pump inside the unit, but I want to move it to another part of the room cheaply.Electrics in a bathroom will need a qualified Electrician as a minimum, not worth taking a chance on this! Could I have your ideas on what options I have please? I am not bothered about having super pressure like I have now. Would a simple electric shower like this be possible with my boiler system?Yes, an electric shower is suitable, but depending on the heat output may require a bigger cross sectional area cable (6 or 10mm)I have had some quotes for a bathroom refit in the last few days but to be honest I didn't understand the technologies they were talking about and felt uncomfortable to ask. E.g. one recommended a separate 10mm cable run from my consumer unit for something (can't remember what exactly) and one recommended a pump in the airing cupboard for something.If you choose a powerfull electric shower then your existing cable may not be man enough for the job as it has to supply the heater in the shower as well, not just drive the pump, which is probably why you were quoted for a new 10mm cable.The other suggestion would move the noise and the electrics out of the bathroom into the airing cupboard but would probably involve more plumbing cost and at least a new fused spur for the pump.Hope I am making some sense. I posted this in the plumbers forums but didn't get much of a response, then figured out this is actually a sparky question rather than a plumber thing.Plumbers!
I would go for another power shower, if u replace it, it will certainly be quieter,
If you can keep it in the same location, it will bring the cost down considerably and a spark will do the full job probably.
normal electric shower will cost you to have a decent supply put in
If your cold water tank is in the loft and you not so bothered about the pressure, why not just have an ordinary shower fitted with a hot and cold feed? It's the pressure of the water in the header tank which forces the hot water out of the cylinder, or if that's not enough a small pump fitted next to the cylinder to give the outgoing water a bit of a push
Right I think I've got you here, but
1) when you say possibly putting a small pump next to the cylinder, wouldn't that create a lot of work for a sparky to provide a new feed from my consumer unit?
2) So what would a "normal" shower look like ? something like this?
@ Clink - I read your response thanks for the multiple efforts for replying :-)
@ KevinS - OK that's certainly an option for me. Aspirante Thermostatic Power Shower - Chrome somethign like that? If I wanted to relocate it 2-3 metres in the same room though, how much work as a sparky do you think that would take?
The supply for the pump doesn't have to be a new circuit, it can be spurred off an existing circuit. The plumbing side of it isn't necessarily that difficult either with connections generally being with push fit connectors.
Hi all,
If your existing unit is REALLY noisy, it is most likely a damaged/worn pump, and/or cavitation. How long has the unit been installed?
Regards
Billy
Right so the sparky work required to provision a pump is less than it is for an electric shower due to the electric shower needing a new 10mm cable ran from the fusebox. Got you.
Is the one I linked the right type I should be going for? Mixer Showers, Shower Enclosures, Bathroom Supplies
