Warning ,,,, You may need to increase the size of your header tank due to the new pump emptying it faster than it fills mate ,
how come? I have a powershower with a pump in it at the moment, so a mixer shower even if I get a pump for it should only be the same water output shouldn't it?
If your existing unit is REALLY noisy, it is most likely a damaged/worn pump, and/or cavitation. How long has the unit been installed?
Regards
Billy
