J
jumpin jax
I recently contacted UK Power networks as to whether it was possible to install a switch fuse in the meter cabinet as the consumer unit is over 8 metres away from the head. Their reply was 'it has got nothing to do with us, you should contact your supplier'.
Problem is that this is a new build and the owners have not chosen their supplier yet and what if different metering companies have different rules. I have even seen consumer units in these so what are the rules?
The trouble is , is that there is not any cupboards within 3 metres of the head
The meter cabinet belongs to the property owner.
As meters are quite small now, there should be plenty of room for everyone.
Is this definately correct as I was under the impression that it was not allowed, I may and am probably wrong about this but I will be gutted as using the cupboard would have helped me out on several occasions.
same comment as the last 3 posts. just bung it in there.
I just remember as a newly qualified and very green electrician getting a verbal assault from a metering guy for running an SWA through a cabinate.
Feel like I should have nutted him now lol
Well i will just go ahead and install the fuse and wait, as murdoch says i will put well to one side so they really cant say, the meters are quite small compared to the analogue ones
It used to be frowned upon a few years ago, the DNO's used to get the hump, but stuff em and shove it in there.
Charge the supply company for storing their equipment on you're property.
We can all dream.
The boxes are the property owners property and you have every right to install your cu in there if you so wish just not a good idea because some smart assed kid will end up gaining access and shutting you down lol
I've known them to moan about equipment being fixed to their board on a cellar wall in the past.
Thanks for all your replies, i have got to install the switch fuse this week and will let you know if there is any comeback when the meter operators come in.
