C
charsam
Hope somebody can help me.
I am installing a couple of 32A 3 phase sockets in a factory unit and I am not quite sure if I need to have a local isolator for each one or if I can connect direct from the fuse board?
They are located within 2 metres of the board so not sure if really needed?
Any help appreciated
i, personally would fit isolators. in an emergency, it's obvious, better than having to go to the DB and then wonder which MCB is which.
I usually fit the Gwiss interlocked type, but there's no regulation that says you have to fit an isolator. The socket itself satisfies as a means of isolation.
Depends what is been plugged in really if the item will be plugged in on load then an interlocked isolator is required to stop plugs been fitted or removed under load conditions.
Whenever I fitted any form of industrial socket,240 or 415 I always fitted an isolator,if nothing else it saves them from the potential damage of being repeatedly disconnected under load.
