mmm criticise others for not being helpful but how can you give accurate advice when you are guessing at the loads if you have not seen the instillation how can you say one of the 30A will be an oven ? and he stated " and 2.5 mm csa for the 30 amp two of witch are radial and one is a ring " radials on 2.5 should be on nothing more than a 20A but he have no idea what is what so we cant really give any advice and to give wrong advise is worse than no advise from the knowledge the op shows from what he describes then the best advice has been given get a proper spark in and watch and learn and think hard about his comment about having 3 kids to feed you cant feed them if in prison for killing someone else with poor wiring because he does not care !
He can't feed them no, but the state of our prison service he'll be probably able to get the full qualifications and training he's severley lacking at the moment inside haha.
Shouldn't joke about something serious i know, as above, get the proper people in and watch and learn. Electrics are lethal in the wrong hands.
Did i not say to make sure any cables are capable of carrying fault current? Or does that not say that?
Whats it got to do with fault current?......a 2.5mm cable on a 32a radial is a potential overload problem,which is why it's not permitted in bs 7671.....nothing to do with fault currents.
Is it not all part of the total picture?
- - - Updated - - -
And at what point did i say put a 2.5 on a 32amp breaker?
I tried to keep out but have to jump back in, the op was asking silly questions IMO, just because 2 or 3 even 2.5mm2 cables are connected into an existing 3036 30 amp fuse doesn't mean the new mcb installed can be 32 amp, they could be 3 radials FFS, a spark needs to look at the job, test the circuits through and then connect the existing cables if they are connectable to the appropriate breaker, I have seen old 3036 wylex dbs with 4 fuses in them and when I have fitted a new board have 8 new circuits, several fuses have been overloaded, I have seen 5 2.5mm2 cables wedged into a 30 amp 3036 before, Hawk81s comments are right when he questions the over current protection, I am pretty suprised this thread has got to this stage, going back 20 posts or so, I say again if you cannot understand how to change a board don't do it. there is more to changing a DB than just connecting cables to the nearest equivilent sized circuit protection, what a bloody joke this thread is turning out to be.
I watched british gas fit a boiler once.. Im going to ask the plumbers forum how i can fit my own next time..
How will it go down ??
ive just moved mine from the kitchen into the bathroom dave and extended the gas supply pipe, i,m not qualified in any way to do it, do i go to jail?(grin)
Well obviously from the load resulting in ccc of the cable required, which results in length, voltage drop, and of course R1+R2, resulting in final Zs for fault conditions to comply with the chosen mcb.. But i am sure the OP knows this but just wanted a few pointers as he is a little apprehensive. This is obviously turning into a witch hunt because of saying how unhelpful some of you are, we were all there at some stage, for me i have had enough of the slagging off and off. Thanks to those who have made this an interesting forum in the past.
i think it's clear from the op's opening post that he does not know what he is doing. He has stated that he will replace the three 30amp fuses with 32amp mcbs when he had already said one circuit was a 2.5mm radial. After that I would have to doubt his ability to check correct Zs for each circuit ect
why thats silly big dave! even preposterous
i used a length of garden hosepipe and 2 jubelee clips
i like to do things right
its not a witch hunt jumpin jax but if you re read the initial first post and you subsequent replies you will see the information was not correct i am sure i am not the only one that see's this given the number of comments on it and as i stated giving wrong information is worse than giving none. when we offered the result of getting a qualified spark in and for the op to observe it is still by far the best advise he can be given because there is no way we can second guess what he is looking at without being there. but if he was to observe and question what was being done he would learn far more than any short course and i would hope then continue to become a better and more confident spark.
The point here were all making is just because an existing DB has a 30 amp fuse in it doesn't mean when you put a new DB in you automatically add the cables from the existing 30 amp fuse to a new 32 amp MCB, anyone who automatically thinks that should not be allowed to practise our art, it is obvious testing and inspection of the existing installation should be carried out and determined before connecting any existing cabling to new Distribution MCBs, of course there will be times when existing cabling is connected to new circuit protection which matches in amperage size the existing, but not always and guessing it is which is what the op seemed to be assuming is why we are all up in arms here
Like already said, this is very basic knowledge for an electrician, to carry out a fuseboard change you should know this information without seeking it, many times problems crop up when you change an old board for a new one, especially with rcd's in the circuit, and if that doesnt get you fault finding- theres always a possability for the borrowed neutral situation too........just concerned realy, sorry if this sounds too negative but this information is very real and true and without knowledge/experience can cause problems down the line..............................
