E
Engineer54
So in the instance of the bigger static vans that are more permanent would you consider PME? I don't see how you could consider PME to be honest.
Why Not??
I'm pretty sure that there is a member here, that actually lives in one of these bigger mobile homes on a residental site, that is permanently connected to the mains power supply and that the supply was PME
There is nothing bare feet on metal in these units, normally fully carpeted or laminated throughout, most of them have decking around the place too!! ...lol!!! Some of these things are massive, totally uncomparable with your typical road and holiday caravans...:smiley2:
To be fair in my ignorance ive never really read section717 as regards to static caravan's...
Suppose its up to the inspector at the time as to what regulation applys. Common sense required. Thanks for making me more aware of 717 though.
This is the only earth rod that I could find on the site which is poorly installed at best.
This is the first in the line of 2 external distribution panels through the site that I could find
This is the only metering position that I could find at the site and the earth rod is installed behind this wall with the earth cable running up the side of the wooden back board straight from the rod to a mass joint behind the make shift enclosure above the isolationwhats the RA reading there? under 1667 perhaps or even under 200, it well maybe that one rod serves all TT supplies haha, it looks crap but it may be the case, I still recommend converting to tt at every 4 caravan plug points, can you confirm the supply at the distribution end is tn or tt?
AKA Kermit & Miss PiggyAre you sure the owners are going to stump up the money for all the changes?? I agree that as it stands now, the existing installation looks to be a pig's ear, designed and installed by Muppet's!! lol!!
