S
SirKit Breaker
The wiring regs is a Non statutory document, therefore it is not a legal requirement, unlike building regs etc. It is however a guidance document for use to enable compliance with the Electricity at Work Regs, and other associated Statutory documents, which are a legal requirement. You do not need to comply with the wiring regs, as along as whatever you do is as good as or better than the requirements of BS7671. The wording in the BS7671 says something along the lines of "Whilst it is a non statutory document, compliance with it will ensure that all the requirements of the EAWR will be met.
Although BS7671 is not a legal requirement, it can, and will, and has been used in a court of law for successful prosecutions, as being the standard required by all the statutory requirements.
BS7671 underpins all the legal requirements, just have a look at the notes down the righthand side of any plans that you work to as a good example.
Cheers...........Howard
