The wiring regs is a Non statutory document, therefore it is not a legal requirement, unlike building regs etc. It is however a guidance document for use to enable compliance with the Electricity at Work Regs, and other associated Statutory documents, which are a legal requirement. You do not need to comply with the wiring regs, as along as whatever you do is as good as or better than the requirements of BS7671. The wording in the BS7671 says something along the lines of "Whilst it is a non statutory document, compliance with it will ensure that all the requirements of the EAWR will be met.
Although BS7671 is not a legal requirement, it can, and will, and has been used in a court of law for successful prosecutions, as being the standard required by all the statutory requirements.
BS7671 underpins all the legal requirements, just have a look at the notes down the righthand side of any plans that you work to as a good example.
Cheers...........Howard
Is it just me or has anyone else ever wondered how many people do not actually understand the actual legal standpoint regarding BS7671 aka the wiring regs? The number of people who ask " is such and such legal and if so under what reg" the regs are NOT a statutory instrument and therefore not enforceable by law the actual enforceable bit is the EAWR. If a case came to court where you had not followed the GUIDANCE of the regs then it is true it may not be looked on favourably, but not following the regs isn,t an offence in itself.
I'm quite confident I understand the majority myself Phil , but know there are a few here who do not even know what they are haha
looking at a statement in osg para 2.3.2 "minmum should be 25mm" but understand what you mean, just wanted to be sure
"should be" is not a statement of fact. Rewires and new builds, 25mm for the install yes, existing installations 60/80A fuses, 16mm is fine.
If that is the case, then -
Saying the 'minimum cable size should be 25mm'. is even more meaningless.
That means therefore, the minimum cable size is not 25mm.
So what is it?
I agree phil, it does seem that BS7671 is sometimes enterperated as the law but isnt it simply a case of following BS7671 strictly in order to prove that you are working within the EAWR, or at least thats how i see it
conformance with one.....demonstrates compliance with the other.....but if it went to court it would be the EAWR 1989 they waved about....not BS7671....
Yes, I realise that, as you can tell from my previous posts.
I am merely pointing out how poorly written and useless the OSG is.
BS7671 may not be statutory but it's a good code of practice to follow to ensure a safe installation, and also compliance with EAWR1989 and others, which are the law.
Judging by the householders who come on here and start asking if things are "safe or even legal" it is usually when something looks a bit of a mess, eg T&E clipped direct, and they want an excuse not to pay up - they weren't bothered when they thought they could get a discount for paying in cash or not having the job notified.
Of course saying "you can't do that - it's illegal" sounds more authoritative than saying "you shouldn't do that - it's bad practice". I was told by a publican once that it's "illegal" to wipe wine glasses with a tea towel when they come out of the glass washer. He also told me it's "illegal" to have still water coming out of the fizzy drinks dispenser. I wouldn't be surprised if he's one of the ones going around declaring Snakebite "illegal".
The fact that BS7671 is non-statutory is no reason to flagrantly disregard it either - wiring up boats we use 3 core cable (2 numbered, one G+Y CPC) for connecting 2 way lighting; the G+Y is used for the common, not sleeved or anything. I queried this by starting "it says in the regs..." but was shot down with "regs don't apply to boats!"
Maybe not but I don't see that that's any reason not to properly identify anything. By and large BS7671 was written with electrical principles in mind for the purposes of making installations safer, and not just some arbitrary rules written for us to play along with for fun - "Simon says put everything on an RCD" etc.
i know you already knew the answer to your own question.
i was merely pointing out to readers that they should think about how and why a cable selection is made.
just very subtly.
