T
tazz
In what respect will having a thicker dialectric provide an unneeded higher breakdown voltage make it "work better"?
Do you also advocate using a 45Amp pull cord switches for a 9W CFL light will "work better"?
:24:
The working voltage of 5v was close to the knuckle on these cards a yes a higher voltage cap will last out longer, as to a 45amp switch on a 9watt lamp using 0.04 amps.....the switch contacts should last alife time.....!
