Better off just buying a new one for the hassle
Just re cap....(good pun) change for higher working voltage, as you can see the cap is lager but will work better.
In what respect will having a thicker dialectric provide an unneeded higher breakdown voltage make it "work better"?
Do you also advocate using a 45Amp pull cord switches for a 9W CFL light will "work better"?
:24:
The working voltage of 5v was close to the knuckle on these cards a yes a higher voltage cap will last out longer, as to a 45amp switch on a 9watt lamp using 0.04 amps.....the switch contacts should last alife time.....!
Damn Wikipedia and its links, that's 2 hours of my life I'll never get back!
There were shed-loads of caps that failed a number of years ago - some bods stole the formula for the electrolyte from the company they worked for and set up their own. But there were errors in the formula, so they failed prematurely. Google will probably find all the details.
As already mentioned, you need a hot iron as these caps are usually connected to the copper power and ground planes, so they suck a lot of heat.
Why its a 5 minute job, common fault and one expensive graphics card...?????
