J
jenions
Can I just use mains spots in polystyrene tiles or do I need to use anything specific? Plenty of room above so heat dissipation isn't an issue.
I personally wouldn't like to risk it. The frame of the fitting has got to reach a pretty high temperature if there was a 50W GU 10 lamp in it.
Yeah Agree, unless it is LEDs, however even they can get warm, sounds Dodgy, I may be wrong, sounds a little scary though.
I turned up at a commercial job once where they had done this, GU10 50w bulbs although it had not cause any serious damage in the tiles it was clear that they wernt designed for it
What about fire rated? I'll fit whatevers safest, just wanted to see what's the best way to do it. Cheers lads
I wouldnt myself... but i'd think LED would be OK. If it's not your own house, and ur gonna do it... put fittings in that are made for LED's only
12v 240v still let off too much heat.. Only trouble with Led's can you be sure that they wont put Halogen in at a later date?
Surely the Poly ceiling tiles wouldn't comply with building regs if you fit new lighting and have to notify it or am i wrong. I would've thought these would be a fire hazard especially with the poisonous fumes they give out if fire does break out.
12v 240v still let off too much heat.. Only trouble with Led's can you be sure that they wont still Halogen in at a late date?
Very Good point Dave, you could use proper LED fittings I suppose, although I'm not convinced they won't get hot.
Its an off license and there ceiling tiles for a false ceiling, will have a look at what's best suited
use the all in 0ne LED fittings. if lamp goes you change the complete fitting ang nobody can fit halogens. they're £35 ish.
Ceiling tiles in a lay in grid ceiling aren't polystyrene bud. Those tiles should be ok for fittings but i would suggest cutting a pattress to fit behind the tile.
ah I thought you meant the white fragile tiles that glue to old ceilings in houses, if the 600x600 type then you will be fine with LED fittings IMO
- - - Updated - - -
We both posted at the same time sintra haha.
