J
Jimmyb
Hello all, can someone tell me what the best cable is for connecting hobs and ovens i thought heat flex but now I'm being told sparky ive been working with today that t&e is fine
I also wondered if connecting the 2-kW oven straight into the the cooker switch not fused apart from 32amp mcb is ok as i was thinking it would need fusing down to a max of 20amp due to it load
I only been in the industry for 3 years and he has been init for 30 years so i just agreed with him but i cant see how he is right.
Have i been doing something the hard way by using heat flex and end up putting in a hob isolator and a fcu for the cooker
Many thanks
Jimmy:):confused:
I have always used T&E from the cooker outlet to the oven,hob usually has flex attached and straight into another cooker outlet,both controlled from double pole switches.
just out of interest, if you had a seperate electric oven with a gas cooker, could you have them both off the same cooker switch?
Could be wrong but i seem to remember that if the oven is built in then T&E is fine. if it is free standing them 10mm flex should be used
I tend to run the cooker switch on to a 20 amp mcb,you could even use a 16 amp,in 4mm cable.
Then to a double socket,for ign hob,and the cooker on a 13 amp fuse.
All cookers should have a max demand in kw on them.Then do your sums.
Must admit i ALWAYS run the cooker circuit in 10mm and sometimes 6.
Even if its a 13A single.
yep,thats fair enough,you don't know what size of oven is coming,I suppose.
In terms of that situation though....
why 4mm if 20 or 16amp
For the simple reason that whenever I run a radial,be it sockets or whatever,(although not lighting)I run it in 4mm,so have it handy,plus the 4mm will take on extra load.unless theload exceeds the 4mm cable safe capacity.
Jimmyb,
billybob,
