E
ElectricNewbie
Hi everyone,
I am currently conducting some research into electric crimping tools for a research project. I found it very difficult to obtain sufficient information on the tool itself and the fields of application. I am aware that electricians use manual crimping tools on a regular if not daily basis, but do not know when electrical crimping tools are used. I found that there are several types of electrical crimping tools such as pneumatic and hydraulic tools, but still cannot really understand the difference. I would really appreciate if you guys could drop some knowledge on the topic, perhaps even name the main suppliers and the knock out criterea for such tools.
Many thanks,
Tom
Hi Tom, welcome to the forum. The main reason for using a electric rather than a hand crimp tool is the increased crimping pressure available, allowing lager sizes of crimps to swaged. The highest controlled crimping pressure is produced by hydraulic crimp tools that can be either hand or electric pumped. A good manufacturer of electric and hydraulic crimp tools is Klauke.
Klauke Textron: Presszangen und Schneidwerkzeuge
Are you looking for a crimping tool to be used in a factory production environment or on site for commercial and industrial installations?
We used to install lots of 240mm double insulated tri-rated cable with hydraulic crimpers, which are great.
However we did have a battery operated crimper make by makita, this was great but used to leave tags which needed filing off.
Personally I would prefer to use a hydraulic crimper
Have used one similar to you stu, don't know if it was made by makita but used makita batterys, was brilliant bit of kit, crimped up to 240 I think.
Most probably the same, nice and quick but you don't get the feel of it doing a good job...
I just prefer doing stuff manually
Hi Marvo,
I am looking for battery powered crimping tools that are most likely used in factory production environments and would be classified as industrial tools. I have looked into a bit more yesterday and found a range of suppliers. However, I am still not 100% sure what criterea would be used to evaluate a tool (eg. crimping pressure etc). I am also unsure in which industries these tools are used.
crimping pressure will be specified by the crimp manufacturer,some people overcrimp cables and this can be a problem,with the old Burndy hand crimper you adjusted the size by turning a knurled adjuster on the tool and people would often do one crimp and then wind it in a bit further to get it tighter this in itself can lead to cable damage. on a hydraulic crimper the crimp is completed when the 2 halves of the die meet so assuming you use the correct die for the size of cable overcrimping should not be an issue.the battery crimpers are most likely to be used in situations where there are a lot of crimps to be done,also some firms use them as a way of cutting down on RSI,power networking companies are probably likely to be your best bet.have you thought of contacting a manufacturer for information regarding who they supply?
Hi Phil,
I have already tried to contact several firms, however it is difficult to obtain any information as some firms treat this as confidential. I thought that the airline and railway sector might also have a use for these tools, as they work with larger cables in their machines.
ElectricNewbie,
ElectricNewbie,
