another solution smokes on own circuit with 1 light on it aswell mybe the light nearest db i.e outside electrical cupboard
From the OP:-
"Where do you draw the line and at what point is it not acceptable to connect an item of current using equipment to a lighting circuit that isn't actually a light?"
A. Anything you want or need to feed from the circuit in question. Long as the MCB and cable can handle the load of which your introducing.
There is no such thing as a "lighting circuit" or "socket circuit", they are all circuits that was designed to function as a lighting or socket circuit at first and then through later design, calculations and installment became a circuit that feeds more than one type of load.
Q. Can the cable, MCB/RCD handle the new load? Is the cable the same size? no need for a fcu then. What is the total load at the moment and what will you introduce onto it?
From the OP:-
Exactly, and well put. A final circuit that serves lighting or power outlet accessed by 13A sockets does do not automatically become 'exclusive' lighting or socket circuits.
Thanks again Paul.
Thanks again Paul.
- - - Updated - - -
sorry, cocked that up a bit
Volts, you can always do stuff like this:-
Thanks again Paul.
- - - Updated - - -
Very nice lol. Bit in ya face though haha
Voltz is one of my many forum friends + we speak to each other now and again. No insult intended and he will not see it that way, trust me.
Ive been away from the forum for a short while and its nice to come back to welcoming friends :)
