J
johnty
We have a dormer over the bathroom resulting in a small sloped area in one corner over the bath. The old extractor was fitted in to the vertical part to the side of this slope (if that makes sense) but faces away from the shower/bath. It was never really up to the task when it was working.
As we are going to be pulling the old artex ceiling down and replacing, would re-siting the fan over the shower, as part of a shower light be worthwhile or would just replacing it with a more powerful fan in the orginal postion do the job?
Cheers,
Johnty
difficult without seeing it, but i would be inclined to fit a more powerful fan in the existing position. buy a fan that can be mounted either way, then if you decide to relocate it, you won't need to buy another fan.
From past experience many years ago....It was always advised to fit the extractor fans diagonally opposite the entrance door to the bathroom, therefore creating air movement from the door across the room to the extractor fan. That said, not always able to do.
The main thing is to get air movement, no air movement no extraction.
I would tend to install an inline extractor fan (in loft space) with a selv light fitting above the actual shower area.
In-lines are a lot more powerful than.. err whatever the others are called. The worst (from my experience) are the extractors with a built in light, which blocks most of the airflow, and the last one I fitted had a specialist LED lamp in which was a different colour to all the rest and horribly flickery and the instructions forbid you for changing it for anything else. Oh yes, in-lines are a lot quieter, too, particularly if mounted on woodwork that is separate to the ceiling joists (roof timbers, or similar).
The current position is opposite the door and has a short distance to go although it does have to do a right angle to the outside. If I did move it, it would need to be mounted in the ceiling and I'm concerned that it would look rubbish if it wasn't one with a built in light which obviously must restrict the airflow.
Penrith is a tad too far for me !
If you overventilate (more air changes per hour) you will be increasing the cost of heating the property.
If you underventilate you will have moisture laden air in the room for too long and this will result in condensation staying around on cold surfaces and you'll get mould in small or large amounts depending on general wiping down etc.
Unless you use Single room heat recovery the internal doors need to be undercut by 20mm above the floorboards or 10mm above carpet to allow cross flow.
Generally in the uk although not at the moment ... the prevailing wind is west to east so the idea is that air blows in through the background ventilators on the west and goes under the gaps below the doors and out through the east facing window background ventilator (if fitted).
How leaky is the property ? by this i mean in terms of airtightness ? is it a modern airtight property or an old sieve ! with open fireplaces, single glazed windows, etc ? Has it got background ventilators (trickle vents)
Are there any Gas appliances anywhere near the bathroom ? You need to be aware of the effect on pulling back poisoness gases into the property.
By the sounds of it there is a duct of some kind from ceiling to outside , is it rigid duct or flexi ? rigid presents less resistance to air flow therefore increasing the efficiency of the fan motor. If flexi it needs to be expanded to 90% to decrease resistance.
How long is the duct and does it run uphill ?
If it goes up to say a roof terminal then your going to need a continuous running fan or a condensate trap to stop water running back down into the motor.
Personally i'd go for an Envirovent Filterless but they can look bulky on a ceiling, however you can get a recess kit if you have access above, they automatically ramp up to required speed to track the amount of water vapour
and have apull cord over ride for odours.
The position of the extract point is important to provide efficient ventilation , the fan will pull from the easiest path it can be it either from under the door or via the background ventilator. Don't get too hung up on it but its worth getting right.
Then if you want to be really sure buy an Airflow LCA301 airflow meter ( £360 ) and check it performs according to the requirements of the type of fan as per Building Regulations Part F further guidance is available in the Domestic Ventilation Compliance Guide both documents are downloadable free and good bedtime reading !
