Y
YoungBart
Hi all, I do apologise if this has been posted before, But I'll be damned If I can find it. I have my AM2 this week, and I'm fairly confident In all aspects of it (Famous last words). But I've just hit a snag while trying to work out the lighting.
Apparently the circuit is a 2 way and intermediate, wired in 1.5 t&e, with the feed going to the switch. (I can manage that bit)
and the strappers and switch wire are all ok, But what about the Neutral, I've just seen somewhere that says I need another legnth of cable between the first 2 way switch and the last 2 way switch with the Brown unused (in a connector) and the neutral Joining up with the feed Neutral and the Neutral from the light (again in connectors).
Anyway I've done a quick diagram (of sorts) does it look ok to you (from a technical point of view NOT artistically)
