G
gutterball
The picture of testing ir in the link shows a connection on to l & cpc. when i use my mft i croc clip l&n together on 1 probe and cpc in the other.
Yeah, it does actually say the following in the text of that Seaward link:
"However, the absence of a 3 pin plug requires the use of a tester with a point to point test function and can involve other changes in test procedures. For example, care should be taken when performing an insulation resistance measurement on an item of fixed equipment and it is recommended that line and neutral connectors are linked to eliminate the risk of damage."
So, not great picture from them, then!
Hi
So if I was to Pat test a Hand dryer in a school, I would have to isolate the circuit, disconnect the cable from the fused spur, connect the MFT to the lose cables and test, is this correct?
O if I did not have MFT and just a PAT tester would I be able just to fit a tempery 3 pin plug and test?
No my understanding is you are not competent or insured if you are a "PAT" tester When I did the course 2 years ago the discussion was that this was the elephant in the room and they know its a problem because one Scheme provider said well we can cobble together a short course to get these lads trained and the insurance industry said no. Hence why nobody wants to discuss it .
My view is that the insurance industry will dictate this so say they get a lot of claims in the rental sector and find some of it was from FA and then realise it is being omitted then they will insist on it and if they do "PAT" companies could have problems
yes thats rightHi
some of it was from FA! what is FA?
fixed appliancedno i am not a pat tester as yet. I am doing a domestic electrician course, so hopefully i will have the knowledge that is required.
Some of it was from fa! What is fa?
Yep it was never officially called PAT but someone thought it had a good ring to it
4. Urban myth PAT testing companies say fixed equipment is a part of the fixed wiring so gets tested along with fixed wiring testing ie during an EICR Well no because the Schemes and colleges got caught out with this they recommend that electricians do this whilst checking the fixed wiring but there is no obligation to do it.
Like a guy who came on and said "I am a professional PAT tester being doing it for xx years if anybody want to tap my vast knowledge of PAT then get in touch"
