C
Chrisel
Called out by a plumber I do work for. He had recently installed a new zone valve and chaged CH/HW programmer. A fortnight later the customer calls him because he has lost all heating. Plumber turns up, realises 3A fuse has blown in switched fused spur. He can't change it without it blowing. Calls me.
The spur supplies the boiler which, as well as central heating, heats water into the tank. Spur therefore also supplies programmer, zone valve and cylinder stat. I identify the cylinder stat as the issue; we replace this. Everything starts up, we run the system. Everything is working well.
No. Two days later the customer calls the plumber, the fuse has blown again.
Before I return to the property and recover exactly the same ground, is there any advice out there as to what might be causing this. Could there be an underlying problem that I missed, causing a problem through the stat. I don't want to have to return every 2 days and install a new cylinder stat.
