P
pabloiseguro
Hello. Regarding some Spa installation instructions, I can't understand the underlined sentence:
The SPA tub should be connected to the building’s electrical wiring permanently. The electrical wiring should be equipped with theappropriate manual cut-off mechanism, enabling the opening of contacts on each power supply pole.
Any ideas?
Any ideas?
To any Electrician, it's stating the obvious, therefore hire a qualified electrician to install the Spa's electrical installation!! Don't be tempted to undertake this work yourself, there are other safety factors that need to be taken into consideration apart from this manufacturers instruction.....
I don't suppose the OP is one of those guys rolling up on hot tub jobs and just whacking them into IP rated socket outlets?
Far too many crappy hot tub jobs out there. Come to think of it, I don't think I have ever seen one done correctly?! (apart from mine that is :D).
pabloiseguro,
Guest111,
