G
Geordie Spark
I quite agree, although I'd have preferred to see another inch or two of copper.
Well you can have that if you want.
The plastic straight coupler is demountable and reusable - it just unscrews - and the short bit of copper is connected to the stop cock with a compression fitting, so you only need a longer bit of 15mm copper and a new 15mm olive to reconnect to the stop cock, then shorten the plastic pipe - remember to refit the insert into it - and shove the coupler back onto it.
Personally, I would have prefered to have the whole thing in copper with not a bit of plastic anywhere on the job, but I'm old fashioned.
