A
Andrewr3
Had a couple of showers to fit over the past two weeks, also quoted for a complete new install. The tricky part is deciding what advise to give the customer if it is worth paying extra for a 10.5Kw. As it happens I got to run and play with both an 8.5 and a 10.5 within a few days of each other. My conclusion was that if you like a stonking hot shower and you have the water pressure available then a 10.5Kw might be what you need. Otherwise I concluded a 9.5 would do for most people. The 8.5 (7.8Kw at 230V) was OK too, I would call it adequate and economical on water and energy.
The 10.5Kw when running really hot produced a lot of steam/moisture in the air so bear in mind what ventilation is available as well.
7.2kw. Was fine for me growing up, and it's fine for my kids. Less steam, less cost in electricity.
forget the electric shower.....mixer shower fed from an unvented cylinder hot and cold at mains pressure....magic...
Andrewr3,
Guitarist,
