Currently reading:
Darkwood
Staff member
Mod
Supporter
Probably got a bit lucky here. Did Zdb and didn’t visually see what was going on, been testing Easy 9 boards this week so the line on the right didn’t really click with me. Turned the main switch on to do the RCD tests and my eyes caught how the cables were coming into the back of the board so I was wiggling round right next to the neutral bar, then I saw it ?.
Nasty!
About 20 years ago I turned a Wylex off at main switch, cut through a T+E cable with damaged wire cutters, got a right bolt and blew the main fuse. Whole board was reversed.
Once bitten twice shy, and been sticking a 2 pole on the N and E ever since.
easywy. switch off what you think is the OCPD. plug in kettle. if you ain't got tea within 5 minutes, it' proven dead. 9unless , of course, the kettle is FUBAR, then it's guess again.
I know a sparks who used to turn circuits back on to boil his kettle then forget to switch the circuit back off before grabbing the bare cables he was just working on before brewing up , must have seen him zap himself 3 or 4 times one month like this …
he was an cps approv sparks as well
L
That is exactly the point
The more you use voltsticks the more you depend on them
I don't go near anything without one
i have 3 of them in my toolbag. 1 is slightly different.it has a forked business end, so in a bunch of conductors, as you sometimes get in multiple switches. it don't pickupfrom adjacent cables. you just put the forked bit over the suspect conductor.
