Discuss 1 phase 2 pole 400v pump wiring in the UK Electrical Forum area at ElectriciansForums.net
Hello. How i should connect this 1 phase 2 pole 400v cooling pump? If i apply 1phase 230v and neutral it Will only growl and "spin" very very slowly.
Thank you for help.
I know that, but typeplate says 1 phase thats whats confusing me. I measured My capasitor and its charging and decharging
single phase 400v is what the name plate is stating as the supply required.
this could be provided by a step up transformer if you only have 230v single phase available.
alternatively it is probably easier to get a 230v motor instead.
Typically 400V is obtained between two phases of a 3-phase supply (nominal 400V L-L /230V L-N) which is common thorough the UK & EU for larger installations.
What is the motor for, and why did you get a 400V one?
Its for pumping cooling liquid for bandsaw. It came with bandsaw but not working. It was installed ; L1 - L2. Now i rewired it L1 - L1 and now its working.
Reply to 1 phase 2 pole 400v pump wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hi I have a question hoping I can get some help. I wanted to know if there is a 400V 3 phase supply (A/A/A) terminated on the primary side of a...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
