C
Chris14
For 11kw shower what cable size is required for 15m run?
I got asked to install one of those once and his "mate" who was an electrician but out of the country at the time said it could be spurred off the ringGuys, what about this kiddy...
Redwing 12kW Shower
Personally I say 16mm² will be sufficient on a 286m run, but the Regs work it out to be a 120mm²...anyone any thoughts...Muhahahahahaha![]()
GROUNDHOG DAY ? or is it just me ?
you forgot the porridge in the 3kW microwave.
porridge on xmas day ?
are you in prison ?
lol ;-)
are you in prison ?
lol ;-)
depends on the cable type, not very big if MICC is run in :rolleyes2:For 11kw shower what cable size is required for 15m run?
Na in prison they get the full christmas lunch but the Warders have to make do with the sannies they bring in as told to me by a warden friend
Dare I venture to suggest getting a sparky in?
Or has the OP gone away?????????
anyone living next door to the jones's who have a 10kW shower. just plain snobbery.
I have a 43.9kW shower...well actually it's a 150,000 BTU Potterton Boiler...That is only wired on a 1.5mm² flex from a 13A spur, works fine!! (I think the gas connection helps though!)
2, 4mm in parallel![]()
greasy monkeys perhaps:joker:Who in their right mind would want an 11kw shower?
The same loony who surprises you with an 11 kw range oven with induction hob, warming draw twin oven and grill after saying its a double oven and gas hob......
Bit of 6mm and a 32 it is, then.![]()
A 9kw is just as good at getting the grease out of a monkeys fur and i would knowgreasy monkeys perhaps:joker:
