Discuss 12v AC door release conundrum in the UK Electrical Forum area at ElectriciansForums.net
I need to put an exterior grade switch with a timer, to switch a 12v AC solenoid which is fail-secure- so it needs a momentary voltage to open the gate.
All the electronic switches I am finding are 12v DC- but I need AC. I can't just use an ordinary push to make as I need a timer, so the switch can be located back down the alley from the gate out of reach of anyone trying to reach through the bars of the gate.
I guess that as it's only 12v, IP is not super important? Although it would be nice.
Can anyone point me in the direction of something that might fit the bill?
Door frame Stainless Steel Momentary Door Release button : Call Point & Push Buttons - Security Safety Products - https://www.securitysafetyproducts.co.uk/security/call-point-push-buttons/door-frame-stainless-steel-momentary-door-release-button.php
Can you not wire an off delay timer?
Might have just as much trouble finding a 12v Ac off delay
Reckon the solution will have to be a push to make switch operating a low voltage relay followed by a timer circuit, but I'm guessing I'll need an additional 12v DC feed for the input of the relay.
Don't see why you'll need the relay, just 12v supply feeding push to make switch operating the off delay timer, then using the timer contacts to operate the door Solenoid with the 12vac. Will the door solenoid not operate in 12Vdc aswell?
IP is equally of importance as you'll find contact and terminal corrosion a big problem especially as the voltage is SELF, there are many ways to achieve what you want but you need to list your requirements. as above links, you can get ready made kits but if you are intent on making this yourself then AC/DC mix is not a big issue tbh there are simple designs to accomondate both voltages off 1 supply.
If you can list all the equirements then I could give a few pointers.
Reply to 12v AC door release conundrum in the UK Electrical Forum area at ElectriciansForums.net
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Our old Friedland chime all too often now emits a only faint "ding"- because the person at the door (usually a delivery driver) just "dabs" at...
Hi there Complete novice electrical wise. I am refurbishing an old 1950s Injection Moulding machine and looking to replace the Power Timer...
6K
Here's the setup: 400ah battery bank on 12v has a positive line that connects to a 400a fuse, then to a Blue Sea On/Off Switch, then to the...
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
