Discuss 140 V between live and neutral instead of the usual 230 V in the UK Electrical Forum area at ElectriciansForums.net
farmer
Hi lads, yesterday morning there was a fault with the incoming electricity supply in that there was only 140 V between live and neutral instead of the usual 230 V.
Could anyone provide me with an explanation for this?
The neutral from the supply either has not been terminated properly/ loose connection therefore in a normal circuit if there is no return then the neutral can potentially become live so as in your situation the neutral has about 90 volts on it potential difference.
I had the same problem about a month ago a client complained the power had gone out to there house and the cooker was making a funny noise when turned on. Got there measured between line and neutral and got 150V, after asking them they said the DNO had been drilling outside couple of months ago to sort a problem out.
Like Andy said in post 9.
A missing or low phase on the primary side of a transformer can produce some pretty strange voltages on the secondary side.
This is the most likely cause of your low voltage.
Reply to 140 V between live and neutral instead of the usual 230 V in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
Hi everyone, I need some help with an electrical issue I'm experiencing. I recently created a new circuit for an electric oven at my friend's...
