correct, but as it's industrial, who's to say that persons using it are not skilled or instructed?
Who Knows but you need to prove it!! Mind you I did forget that if you label the socket for specific use you do not need the RCD. But I was mainly getting at the original issue of over loading the 16 amp socket that is why I suggested the 20 amp rotary isolator
I hate that regulation - like many of them, please install a RCD, but here is a get out clause just in case you don't want to.
Skilled in what? Using the machine, electrical safety, who ensure's that the employer is training the employee's with these needed skills?
Yes it's one of those vague regs I always thought that skilled in this context meant skilled as an electrician but to what level I don't Know,
No, the operator of the equipment/machinery should be skilled. An Electrician can't be skilled in the use of every piece of electrical equipment/machinery.
Yes if the operator is skilled or trained in checking that the machine they are using is electrically safe so for example if the cable supplying the machine is damaged they know not to use it. It has nothing to do with how the machine works, I am a skilled person as I could tell you if a sewing machine is safe to use but have know clue how it works !!!!
Here we all are discussing what was quite a straight forward question and after 3 pages there isn't a definitive answer. No wonder that we all do things our own way when the big green book is so grey!
you're all a bit muddled in your understandings of the exact defintion of the rcd exemption clause.
rcd protection can be omitted from general purpose sockets and buried cables in work-place installations so long as the users are under the supervision of a skilled person or instructed themselves with regards to potential hazards or have a duty holder ( manager ) with a safety policy in place for using rcd free outlets.
no-one has to be an electrician just to use rcd free sockets in the work place.
Now that makes sense. Why can't they just make the regulation read a little more like you just did?
EDIT: Maybe they do? It's been a while since I actually read it. I just know it's in there.
p 34 BGB. under definitions.
I think when I read up on this long ago, I did find this under definitions as you say. I think I remember my initial confusion better than I did my overall conclusion on the matter. Biff's explantion seemed to pull the conclusion back, hence my edit :)
I think your missing my point - The socket has a maximum current carrying capacity of 16A and is allowed to carry 20A
I obviously fit 32A breakers to a ring main, the difference here is that the 13A fuse in the plug limits the socket outlet to only carrying 13A (The 13A plugtop was invented for this very reason) - There is no fuse in a 16A plug to do this.
Sorry mate but I think you'll find that if someone decides to plug 2 x 3kw heaters into your double socket it will not be limited to taking 13 amp:)
I was not missing the point you were.................read the OSG again................something about maximum load on the circuit.............as long as its not over the rating of the socket etc etc.............
It is not allowed to carry 20Amp...................that is the breaker size protecting the cable mate:)
so...is there a duty holder on site?
if so then that constitutes a skilled/instructed person does it not....
someone who assumes responsibility is it not....
