G
georges
any body have any thoughts been asked to take over barn conversion due to other electricians seemed to have run away he has fitted 16mm swa from the meter box to the consumer unit 20 meters away.know the cable is boxed and plastered in.so first 25mm tails required .or may be fit a consumer unit at the meter and use the other then with the16mm to run the rest of the house after working out the loadrequired for both units earthing is tt any thoughts would be greatfully appreciated:confused:
