Discuss 1984 cable depth Regulation / legislation - New to forum in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
JK01
Hi, cable breached on site. Northern power advised no legislation re depth of cable in existence (holding me liable). Is this correct? Cable found at 170mm below surface.
can anyone provide any document stating 1984 cable depth legislation, and any associated depth legislation?
CAT scan used however soft dig not possible due to cement / brick area.
Is it a HV or LV cable?
What is the nature of the land, is it private or public, was it documented on site plans and TBH 170mm is shallow in the scope of things 500mm to 600mm is somewhere about the ball park depth with a warning tape approx 150mm not the cable.. this has been the case as long as I recall even as far back as that.
If the use of the land, an agreement + documented plans were done then you may have a case as a failure for these plans to be forwarded to other contractors digging the site could be your argument but that's a lot of ifs and buts there.
Are you Insured for such events?
Reply to 1984 cable depth Regulation / legislation - New to forum in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I have a property that I was looking to rent out. Its 12 years old property so relatively new. I had a EICR done from a qualified electrican...
6K
Hello. I'll apologize to start with as due to my lack of knowledge on the matter I'm likely to waffle a bit and call everything by the wrong name...
Many will by now have heard of the new requirements for private landlords, enacted under Statutory Instrument 2020 No. 312, known as ‘The...
13K
Been doing some work at a domestic property, that's had some building renovations done. Whilst the small frontage to the property was resurfaced...
C
Hi, I am looking for some advice, my bungalow was built in 1926 and in the 20 years that I have owned it there has always been an ugly lead pipe...
5K
