Discuss 2.5mm flat cable with a sleeved CPC in the UK Electrical Forum area at ElectriciansForums.net
steady on. it's only 50 years since we went metric. ( a backward step, IMO, I'm still 5'8"and 12st. 10lb. ).on a side note , I think it’s nuts that we the u.k haven’t adopted twin @ earth with a sheeved cpc Yet.
no more Faffing about with little pieces of earth sleeve
The UK earth sheathing looks so amateurish and cheap.on a side note , I think it’s nuts that we the u.k haven’t adopted twin @ earth with a sheeved cpc Yet.
The metric system is superb. I am 183 cm high and 76 kg.steady on. it's only 50 years since we went metric. ( a backward step, IMO, I'm still 5'8"and 12st. 10lb. ).
I wouldnt say the earth should be the ‘largest’ but imo it should be equal size to phaseThe Irish cable is superior for sure. All conductors being insulated with the CPC the same size as the L & N. Does the cable conform to the UK requirements?
As a kid I recall an old electrician say, "the largest sized conductor on a circuit must the earth cable". How matters have changed.
I've always wondered this myself. I gues its just easier & cheaper for the manufacturers to omit it, if its unrequired.on a side note , I think it’s nuts that we the u.k haven’t adopted twin @ earth with a sheeved cpc Yet.
Reply to 2.5mm flat cable with a sleeved CPC in the UK Electrical Forum area at ElectriciansForums.net
