Discuss 2.5mm flat cable with a sleeved CPC in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
I've always wondered this myself. I gues its just easier & cheaper for the manufacturers to omit it, if its unrequired.
Everything in the UK is done on the cheap. Final Ring circuits, omitting insulation from a cable, poky cheap and nasty consumer units, etc.
Having full-size CPC is basically wasted copper. The CPC exists to clear a fault, and if the circuit is designed to meet the required disconnection time / let-through energy then larger is simply not needed.
For some things, like long extension leads, that disconnection characteristic might not always be met, and for other practical manufacturing reasons reasons you might choose to make them all the same size.
I think you mean sized large enough to activate a disconnecting device.
Electricty always wants to return back to where it orginated - the generator, transformer, battery, etc. The earth wire was to parallel the Neutral return to the generator or origin - either full, all geh way back, or party by connecti g to the N at some point on its way back. So that if there is a fault, it gets back to where it came from. So it needed to be the same size as L and N. Seems modern disconnecting safety devices have changed the view.
Before the days of green / yellow I do recall having some 1.0mm single and earth where the earth wire was sheathed green.
The metric system is crap. I am 183 cm high and 76 kg.
impossible for me to visualise those measurements.
e.g. a gallon of water weights 10lb. sssimpless. but 4.54l weighs 4.54 kellogs, stupid.
Status
Reply to 2.5mm flat cable with a sleeved CPC in the UK Electrical Forum area at ElectriciansForums.net
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Every time i go to do this, even with correctly fitting sleeving, it seems to be a right **********")£"$$* of a job getting all three in snugly...
