Guest viewing limit reached
I am looking for some advice. I want to add LED lights above wardrobes in the bedroom. I have installed new cable, blocked end to ceiling rose and, changed the existing single switch to a 2 gang switch. Wired existing permanent live to COM 1 and existing switched live to ceiling light to L1. Looped COM 1 to COM 2 and wired brown to L2. Whist the live at the ceiling rose is live, with a tester when switched on, the blue wire is not yet connected to enable the circuit to be completed and the light bulb turn on.
There are also 2 black wires at the switch which have always been redundant, house built 1975.
My question is how should the blue wire be connected.
Many thanks in advance
Can we get photos of the connections behind the switch.
There may not be a neutral at your switch to allow the lights to work.
Yorkshire
United Kingdom
2 gang 1 way light switch wiring when adding a separate light
DIY Electrical Advice
Thread Tags
Tags Tags
switch
Dickied,
westward10,
