Discuss 2 gang 2 way 500w dimmer rope edge brass in the UK Electrical Forum area at ElectriciansForums.net
Looked at a favour for my auntie, dimmer switch smelling burnt. 10 x 35 / 50 w on each gang, and switch rated at 250 w. Her electrican can' t see the problem says its cheap switches. Need a 500 w dimmer for safety sakes. Wholesalers only got 400w 2 gang or 1000 w single. Dosnt want to change to led. Next step if not make sure all bulbs are 30w, but she likes it bright. Anyone used one as per title
first i'd use a min. of 700watt dimmer. can you not get a plastic twin dimmer and refit the actual dimmers into the existing brass faceplate?
Reply to 2 gang 2 way 500w dimmer rope edge brass in the UK Electrical Forum area at ElectriciansForums.net
I've got a request from a customer today. At the moment they have standard 2 gang 2 way dimmer in their lounge but they want to change it because...
Hi all. I hope you can help please. Does this exist? I’m struggling to find anything matching this. I have a 3 way switch in my living room. One...
12K
Hi there was wondering if anyone can help? I recently got my kitchen done including 8 led lights in suspended ceiling. The light switch is outside...
Hello all, in need of some advice. I have just installed 14 downlights (two circuits of 6 and 8) in what used to be a living room and dining room...
skamuk
Hi There, I have fitted a Siemens 2 gang 1 way dimmer switch the one with 4 square buttons , 2 amber and 2 blue status lights. I wired the live...
Deleted member 9648
