O
Only1harden
Hi all,
Putting in a a hallway lighting circuit on a new dwelling controlled from 4 points, client wants a dimmer but is happy to incorporate just a 2 way dimmer to save getting involved in master and slave units.
Just want to check before the 1st fix that the dimmer could be either the 1st or last switch on the circuit, or should it be the 1st?
As you will read this site is for electrical information and advice. Fancy a good moan? follow the links below:
Welcome to The Samaritans
Penis Enlargement ? Penis Enlargement Reviews
www.thewifeleftandnowallivegotistheforum.co.uk
(if only it worked this way!)
